[mapguide-users] RE: Compile Error: An attempt was made to load a
program with an incorrect format.
airfiol
jllj3 at hotmail.com
Mon Mar 28 09:43:39 EDT 2011
For anyone looking at this thread, the issue has nothing to do with
coordinate systems. in order to avoid confusion, I will restate the issue
that myself and another user are having.
The issue is as follows:
The error "Compile Error: An attempt was made to load a program with an
incorrect format."
This happens when attempting to uses the C++ compiled object library in .Net
/ Visual Studio 2010 on Windows 7 64 bit.
Hello bjoseph82,
I think that you should create a new thread rather than adding to one which
has nothing whatsoever to do with your question about coordinate systems.
The new thread link should work for you.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp6153978p6215009.html
