[mapguide-users] RE: Compile Error: An attempt was made to load a
program with an incorrect format.
brenda joseph
brendajoseph82 at gmail.com
Fri Mar 25 20:37:20 EDT 2011
Dear all,
how can i make my lat long, wgs 84 coordinate system compatible with the
coordinate system of the map for mapguide, so that my buffer tool can work??
Please help
On Fri, Mar 25, 2011 at 9:16 PM, airfiol <jllj3 at hotmail.com> wrote:
> No but I was able to get the same error a different way which may provide a
> clue. I am able to open the sample web site using the Maestro preview and
> also by pasting the Maestro generated URL (which includes a session id,
> into
> the address field. So I know MapGuide is running and the web site works. I
> just need to know how to step through the code in debug mode.
> After installing MapGuide 2.2 RC4 ( the new installer works very well btw),
> I attempted to open the top level mapguide web site using Visual Studio.
> When I run in debug mode, I get the following error:
> Error 1 It is an error to use a section registered as
> allowDefinition='MachineToApplication' beyond application level. This
> error
> can be caused by a virtual directory not being configured as an application
> in IIS. C:\Program Files\OSGeo\MapGuide\Web\www\mapviewernet\Web.config 41
> When I to opened the web site mapviewerajax in Visual Studio and attempted
> to run in debug mode i get the same error as before.
> Error 1 Could not load file or assembly 'MapGuideDotNetApi' or one
> of its
> dependencies. An attempt was made to load a program with an incorrect
> format.
> http://osgeo-org.1803224.n2.nabble.com/Compile-Error-An-attempt-was-made-to-load-a-program-with-an-incorrect-format-tp6153978p6207641.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110326/cab78708/attachment.html
