[mapguide-users] regarding coordinate system
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 28 20:25:06 EDT 2011
restating the problem is not going to help solve the problem
did you try using Maestro to set the co-ordinate system as I suggested?
On Tue, Mar 29, 2011 at 11:22 AM, brenda joseph
<brendajoseph82 at gmail.com> wrote:
> Dear all,
> but if i start using the buffer tool, theres a warning
> Warning: 1 layer was excluded from buffer computation because its coordinate
> system is incompatible with the coordinate system of the map, or because it
> has no coordinate system at all
> how to solve this.
> On Tue, Mar 29, 2011 at 8:05 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> Using Maestro, open the map, it allows you to override the co-ordinate
>> system
>> On Tue, Mar 29, 2011 at 10:57 AM, bjoseph82 <brendajoseph82 at gmail.com>
>> wrote:
>> > Dear all,
>> > how can i make my lat long, wgs 84 coordinate system compatible with the
>> > coordinate system of the map for mapguide, so that my buffer tool can
>> > work??
>> > Please help
>> > View this message in context:
>> > http://osgeo-org.1803224.n2.nabble.com/regarding-coordinate-system-tp6217265p6217265.html
>> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> > _______________________________________________
>> > mapguide-users mailing list
>> > mapguide-users at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer
>> Solution Architect / Director
>> Ennoble Consultancy Australia
>> http://www.ennoble.com.au
>> http://zacster.blogspot.com
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
