[mapguide-users] regarding coordinate system
brenda joseph brendajoseph82 at gmail.com
Mon Mar 28 20:31:14 EDT 2011
yes, i did set the Coordinate Category as Lat Longs and Coordinate System as
WGS84 datum, Latitude-Longitude; Degrees (LL84).
On Tue, Mar 29, 2011 at 8:25 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> restating the problem is not going to help solve the problem
> did you try using Maestro to set the co-ordinate system as I suggested?
> On Tue, Mar 29, 2011 at 11:22 AM, brenda joseph
>  <brendajoseph82 at gmail.com> wrote:
> > Dear all,
> > but if i start using the buffer tool, theres a warning
> > Warning: 1 layer was excluded from buffer computation because its
> coordinate
> > system is incompatible with the coordinate system of the map, or because
> it
> > has no coordinate system at all
> > how to solve this.
> > On Tue, Mar 29, 2011 at 8:05 AM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
> >> Using Maestro, open the map, it allows you to override the co-ordinate
> >> system
> >> On Tue, Mar 29, 2011 at 10:57 AM, bjoseph82 <brendajoseph82 at gmail.com>
> >> wrote:
> >> > Dear all,
> >> > how can i make my lat long, wgs 84 coordinate system compatible with
> the
> >> > coordinate system of the map for mapguide, so that my buffer tool can
> >> > work??
> >> > Please help
> >> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/regarding-coordinate-system-tp6217265p6217265.html
> >> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> > _______________________________________________
> >> > mapguide-users mailing list
> >> > mapguide-users at lists.osgeo.org
> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> Zac Spitzer
> >> Solution Architect / Director
> >> Ennoble Consultancy Australia
> >> http://www.ennoble.com.au
> >> http://zacster.blogspot.com
> >> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110329/e0ad97f3/attachment.html
