[mapguide-users] regarding coordinate system
Zac Spitzer
zac.spitzer at gmail.com
Mon Mar 28 20:38:44 EDT 2011
ok, it really helps if you take the time to explain in detail what you do,
out of interest, what was the map coming up as before you overrode the CS ?
now you need to check that the map layer feature sources have a CS defined
z
On Tue, Mar 29, 2011 at 11:31 AM, brenda joseph
<brendajoseph82 at gmail.com> wrote:
> yes, i did set the Coordinate Category as Lat Longs and Coordinate System as
> WGS84 datum, Latitude-Longitude; Degrees (LL84).
> On Tue, Mar 29, 2011 at 8:25 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
>> restating the problem is not going to help solve the problem
>> did you try using Maestro to set the co-ordinate system as I suggested?
>> On Tue, Mar 29, 2011 at 11:22 AM, brenda joseph
>> > Dear all,
>> > but if i start using the buffer tool, theres a warning
>> > Warning: 1 layer was excluded from buffer computation because its
>> > coordinate
>> > system is incompatible with the coordinate system of the map, or because
>> > it
>> > has no coordinate system at all
>> > how to solve this.
>> > On Tue, Mar 29, 2011 at 8:05 AM, Zac Spitzer <zac.spitzer at gmail.com>
>> > wrote:
>> >> Using Maestro, open the map, it allows you to override the co-ordinate
>> >> system
>> >> On Tue, Mar 29, 2011 at 10:57 AM, bjoseph82 <brendajoseph82 at gmail.com>
>> >> wrote:
>> >> > Dear all,
>> >> > how can i make my lat long, wgs 84 coordinate system compatible with
>> >> > the
>> >> > coordinate system of the map for mapguide, so that my buffer tool can
>> >> > work??
>> >> > Please help
>> >> > View this message in context:
>> >> > http://osgeo-org.1803224.n2.nabble.com/regarding-coordinate-system-tp6217265p6217265.html
>> >> > Sent from the MapGuide Users mailing list archive at Nabble.com.
>> >> > _______________________________________________
>> >> > mapguide-users mailing list
>> >> > mapguide-users at lists.osgeo.org
>> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> >> Zac Spitzer
>> >> Solution Architect / Director
>> >> Ennoble Consultancy Australia
>> >> http://www.ennoble.com.au
>> >> http://zacster.blogspot.com
>> >> +61 405 847 168
>> Zac Spitzer
>> +61 405 847 168
Zac Spitzer
+61 405 847 168
