[mapguide-users] regarding coordinate system
brenda joseph brendajoseph82 at gmail.com
Mon Mar 28 21:07:09 EDT 2011
ok, start from create new source, and i use shp load procedure, create the
layer and after that create the map and set the coordinate system. after
that generate the layout. when i try to browse it everything seems ok, i can
see all the xy and also the scale at the bottom , but when i try to use the
buffer tool, a warning come out. telling me that 1 layer is excluded form
buffer computation. before i set the cs i still can see the xy at the bottom
there it just that the scale is 1 : 10.00,
regarding the map layer feature sources, how can i define if the cs got z?
On Tue, Mar 29, 2011 at 8:38 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> ok, it really helps if you take the time to explain in detail what you do,
> out of interest, what was the map coming up as before you overrode the CS ?
> now you need to check that the map layer feature sources have a CS defined
> z
> On Tue, Mar 29, 2011 at 11:31 AM, brenda joseph
>  <brendajoseph82 at gmail.com> wrote:
> > yes, i did set the Coordinate Category as Lat Longs and Coordinate System
> as
> > WGS84 datum, Latitude-Longitude; Degrees (LL84).
> > On Tue, Mar 29, 2011 at 8:25 AM, Zac Spitzer <zac.spitzer at gmail.com>
> wrote:
> >> restating the problem is not going to help solve the problem
> >> did you try using Maestro to set the co-ordinate system as I suggested?
> >> On Tue, Mar 29, 2011 at 11:22 AM, brenda joseph
> >> > Dear all,
> >> > but if i start using the buffer tool, theres a warning
> >> > Warning: 1 layer was excluded from buffer computation because its
> >> > coordinate
> >> > system is incompatible with the coordinate system of the map, or
> because
> >> > it
> >> > has no coordinate system at all
> >> > how to solve this.
> >> > On Tue, Mar 29, 2011 at 8:05 AM, Zac Spitzer <zac.spitzer at gmail.com>
> >> > wrote:
> >> >> Using Maestro, open the map, it allows you to override the
> co-ordinate
> >> >> system
> >> >> On Tue, Mar 29, 2011 at 10:57 AM, bjoseph82 <
> >> >> wrote:
> >> >> > Dear all,
> >> >> > how can i make my lat long, wgs 84 coordinate system compatible
> with
> >> >> > the
> >> >> > coordinate system of the map for mapguide, so that my buffer tool
> can
> >> >> > work??
> >> >> > Please help
> >> >> > View this message in context:
> http://osgeo-org.1803224.n2.nabble.com/regarding-coordinate-system-tp6217265p6217265.html
> >> >> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> >> >> > _______________________________________________
> >> >> > mapguide-users mailing list
> >> >> > mapguide-users at lists.osgeo.org
> >> >> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> >> >> Zac Spitzer
> >> >> Solution Architect / Director
> >> >> Ennoble Consultancy Australia
> >> >> http://www.ennoble.com.au
> >> >> http://zacster.blogspot.com
> >> >> +61 405 847 168
> >> Zac Spitzer
> >> +61 405 847 168
> Zac Spitzer
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110329/013f8467/attachment.html
