[mapguide-users] How to connect MapGuide Open Source Server
(2.1) to MS SQL 2008 Server DB?
Leendert Ramaer
leendert_r at hotmail.com
Wed May 4 06:18:59 EDT 2011
Hi everybody,
Thanks for the tip to try Maestro, Andrea..
We installed the newest version of Mapguide Maestro.. (3.0)
In Maestro we made the connection with the webserver..
also with the database server.
So we can serve data in layers in our AJAX Viewer.. yes..
But how can you add a i.e. openstreetmap to the map?
1. What is the Feature Source you have to create while clicking the 'New resource' button?
Is it the Web Layout (v1.0.0) template?
If yes, what should we fill in at General Settings? (Openstreetmap.org as Hyperlink?)
2. Or should we create a Vector Layer/Raster Layer Definition?
Thanks in advance,
regards,
Leendert
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] How to connect MapGuide Open Source Server (2.1) to MS SQL 2008 Server DB?
Date: Mon, 2 May 2011 18:08:26 +0200
hi Leendert,
normally, to implement maps you need a support software such as Maestro or Studio
for example, with Studio you can create a connection through the command File -> New -> Data Connection
obviously you choose MS SQL Server Spatial Provider
then you put in the usual connection parameters
regards
andrea
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Leendert Ramaer
Sent: lunedì 2 maggio 2011 15:56
To: mapguide-users at lists.osgeo.org; cst.keet at amersfoort.nl; la.ramaer at amersfoort.nl
Subject: [mapguide-users] How to connect MapGuide Open Source Server (2.1) to MS SQL 2008 Server DB
Dear listmembers,
Installed the free MapGuide OpenSource (version 2.1) today om my webserver (Apache).
I don't know how to connect to the MS SQL database which is operating on it's own database server.
The MapGuide server is working properly on my local network..
There are plenty FDO-providers installed with the data, so that's not the problem..
Do I need to edit certain .dll files in an config or other xml file, to make the connection complete?
Much help is appreciated as I don't have any idea..and I haven't found any helpful guide..
Thanks in advance.
Regards,
Leendert
-- This message has been checked by ESVA and is believed to be clean.
_______________________________________________ mapguide-users mailing list mapguide-users at lists.osgeo.org http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110504/7ebeae90/attachment.html
