[mapguide-users] Re: ODBC Connection
Jackie Ng jumpinjackie at gmail.com
Thu May 12 06:45:17 EDT 2011
Did you install the 64-bit version of MapGuide?
If so, you have to tweak the connection string (either via the XML Editor,
or by the RawConnectionString mode in the ODBC editor) so that it uses the
Microsoft Access 2010 ODBC drivers. Maestro can't do this automatically for
you because there's no way currently to determine the "bit-ness" of the
MapGuide Server it's connecting to.
More info on my blog:
http://themapguyde.blogspot.com/2010/07/connecting-to-ms-access-databases-with.html
As for the Unmanaged sub-editor not working in Maestro 3? Yeah that is a
defect which I'll look into.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/ODBC-Connection-tp6355171p6355267.html
