[mapguide-users] Re: Still raster ...
f fmail.it at gmail.com
Mon May 16 04:39:20 EDT 2011
I am trying to put the values from gdalinfo:
Upper Left  (  497564.606, 5061891.430)
Lower Left  (  497564.606, 5061711.259)
Upper Right (  497717.006, 5061891.430)
Lower Right (  497717.006, 5061711.259)
In the coordinate system in the Feature Source XML.
Without succeeding ...
2011/5/13 [f] <fmail.it at gmail.com>
> Thanks Jackie, another step is done ...
> I run gdalinfo on my GeoTiff file getting this result:
> Driver: GTiff/GeoTIFF
> Files: myfirstimg.tif
> Size is 450, 532
> Coordinate System is `'
> Origin = (497564.606297405260000,5061891.429550633800000)
> Pixel Size = (0.338666666667020,-0.338666666667020)
> Metadata:
>   TIFFTAG_XRESOLUTION=75
>   TIFFTAG_YRESOLUTION=75
>   TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Center      (  497640.806, 5061801.344)
> Band 1 Block=450x6 Type=Byte, ColorInterp=Red
> Band 2 Block=450x6 Type=Byte, ColorInterp=Green
> Band 3 Block=450x6 Type=Byte, ColorInterp=Blue
> In the Feature Source XML editor I have:
> <?xml version="1.0" encoding="utf-8"?>
> <FeatureSource xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="FeatureSource-1.0.0.xsd">
>   <Provider>OSGeo.Gdal</Provider>
>   <Parameter>
>     <Name>DefaultRasterFileLocation</Name>
>     <Value>C:\Documents and
> Settings\User\Desktop\GeoTIFF\myfirstimg.tif</Value>
>   </Parameter>
>   <SupplementalSpatialContextInfo>
>     <Name>Default</Name>
> <CoordinateSystem>LOCAL_CS["*XY-MT*",LOCAL_DATUM["*X-Y*",10000],UNIT["Meter",
> 1],AXIS["X",EAST],AXIS["Y",NORTH]]</CoordinateSystem>
>   </SupplementalSpatialContextInfo>
> </FeatureSource>
> Should I modify this? And how (with the info from gdalinfo)?
> thanks
> [f]
> 2011/5/13 Jackie Ng <jumpinjackie at gmail.com>
>> There are generally two parts to the raster feature source problem:
>> 1. Getting the Coordinate System right.
>> 2. Getting the extents right.
>> You should run gdalinfo.exe on your rasters to see that the reported CS
>> and
>> extents are.
>> If gdalinfo.exe reports no Coordinate System, the FDO provider will
>> default
>> to Arbitrary XY, which you can override in the Feature Source editor.
>> If gdalinfo.exe reports extents but no Coordinate system, the FDO provider
>> will default to +/- 1,000,000 for the extents. This is a bug in the
>> provider
>> (it should return the reported extents regardless of whether a CS was
>> found
>> or not). This can be fixed with the correct configuration document for the
>> Feature Source.
>> - Jackie
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Still-raster-tp6344861p6358283.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110516/33a978d2/attachment.html
