[mapguide-users] Re: Still raster ...
f
fmail.it at gmail.com
Tue May 17 12:45:58 EDT 2011
Thanks a lot Jackie,
I got it!!!
[f]
2011/5/16 Jackie Ng <jumpinjackie at gmail.com>
> You have to create a configuration document. The document has 3 parts:
> 1. The Spatial Contexts and applicable extents (this is what needs to be
> changed)
> 2. The FDO logical schema
> 3. The schema mappings
> If you add that raster in composite mode it should build one for you. Then
> you can edit it via the "Edit Configuration Document" button.
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Still-raster-tp6344861p6368075.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110517/c347876e/attachment.html
