[mapguide-users] Re: Error :connect mapguide maestro with
postgres/postgis
Steve G
steve.golden at morganhill.ca.gov
Wed May 18 13:45:21 EDT 2011
Upgrade to MGOS 2.2 (there were a lot of problems with 2.1 connecting to
PostGIS/Postgres). Use the OSGeo.PostgreSQL FDO provider. Follow the other
well documented online tutorials.
I have connected to PostGIS successfully. At the moment my PostGIS/Postgres
install/config is pretty much default and installed on the same machine as
MGOS. Seems to be working very well...
BTW...I can't remember if I used Maestro 2x or 3.0 to configure the
connection. If you are using 3.0 it could be a Maestro problem, but Jackie
would have probably already told you that.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-connect-mapguide-maestro-with-postgres-postgis-tp6378454p6378771.html
