[mapguide-users] Re: FDO Toolbox Connection
Martin Morrison
martin.morrison at edsi.com
Fri May 27 07:51:19 EDT 2011
Joining a SHP file to a SQL database is a slow CPU-intensive way to display a map. It would be far better to either rmove all of the data to SQL Spatial or to populate the SHP file with the values needed...
Martin Morrison
Application Engineer
Engineering Design Systems, Inc.
3780 Peters Creek Rd Ext SW
Roanoke, VA 24018
540.345.1410
gis.edsi.com
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of yash227
Sent: Friday, May 27, 2011 7:41 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: FDO Toolbox Connection
Sorry But I dont understand what u say..
Here I am giving you short description regarding what i want to develop.
We have develop one web based GIS application using Mapguide Maestro 3.0.
Now we face the problem during showing tool tip data and layers property
data, when I select any parcel, the server usage goes up to 100% even if
only one user accessing the server. The access of data becomes drastically
slower. The SHP is connected with one view of SQL2005 enterprise edition
through ODBC Feture sources. The same view runs very smoothly in SQL2005.
May be this problem occure because of ODBC..
Please suggest me for this problem as early as possible.
Yash..
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Toolbox-Connection-tp6410463p6410746.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
