[mapguide-users] Re: FDO Toolbox Connection
Jackie Ng jumpinjackie at gmail.com
Fri May 27 08:47:18 EDT 2011
Sadly, your version of SQL Server (2005) is not spatially aware.
But if it was (like SQL Server 2008 and newer), you would have both the
spatial and non-spatial data residing inside the same database and using
views to encapsulate a join of these two tables. The view itself can be
recognised as a Feature Class in MapGuide allowing you to create a layer off
of this view and creating styles and themes off of the joined data. Through
triggers or regular update routines, you can keep the underlying tables in
this join refreshed with the latest data.
Do you have the choice of upgrading your SQL Server or using an alternate
relational database?
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Toolbox-Connection-tp6410463p6410943.html
