[mapguide-users] Re: FDO Toolbox Connection
yash227
yash227 at gmail.com
Sat May 28 06:58:15 EDT 2011
Here is the error description..
Please Check it.
<2011-05-28T15:27:45> MapGuide Maestro API v3.0.0.5728 127.0.0.1
Administrator
Error: Invalid repository type.
StackTrace:
- MgResourceServiceHandler.ProcessOperation line 80 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpEnumerateResources.Execute line 123 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpEnumerateResources.cpp
- MgServerResourceService.EnumerateResources line 642 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
<2011-05-28T15:27:47> MapGuide Maestro API v3.0.0.5728 127.0.0.1
Administrator
StackTrace:
<2011-05-28T15:28:10> MapGuide Maestro API v3.0.0.5728 127.0.0.1
Administrator
StackTrace:
<2011-05-28T15:28:14> MapGuide Maestro API v3.0.0.5728 127.0.0.1
Administrator
Error: An unclassified exception occurred.
StackTrace:
- MgFeatureServiceHandler.ProcessOperation line 83 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
- MgOpSelectFeaturesSpatial.Execute line 110 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
- MgServiceOperation.EndExecution line 533 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\base\ServiceOperation.cpp
- MgServerDataReader.Serialize line 792 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataReader.cpp
- MgServerDataProcessor.GetColumnDefinitions line 120 file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataProcessor.cpp
- MgServerDataReader.GetPropertyCount line 103 file
Thanks..
Yash
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Toolbox-Connection-tp6410463p6413962.html
