[mapguide-users] Re: FDO Toolbox Connection
Zac Spitzer
zac.spitzer at gmail.com
Sat May 28 06:59:10 EDT 2011
what's the corresponding log call from your webserver logs?
On Sat, May 28, 2011 at 8:58 PM, yash227 <yash227 at gmail.com> wrote:
> Here is the error description..
> Please Check it.
> <2011-05-28T15:27:45> MapGuide Maestro API v3.0.0.5728 127.0.0.1
> Administrator
> Error: Invalid repository type.
> StackTrace:
> - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
> - MgOpEnumerateResources.Execute line 123 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\OpEnumerateResources.cpp
> - MgServerResourceService.EnumerateResources line 642 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\resource\ServerResourceService.cpp
> <2011-05-28T15:27:47> MapGuide Maestro API v3.0.0.5728 127.0.0.1
> Administrator
> StackTrace:
> <2011-05-28T15:28:10> MapGuide Maestro API v3.0.0.5728 127.0.0.1
> Administrator
> StackTrace:
> <2011-05-28T15:28:14> MapGuide Maestro API v3.0.0.5728 127.0.0.1
> Administrator
> Error: An unclassified exception occurred.
> StackTrace:
> - MgFeatureServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
> - MgOpSelectFeaturesSpatial.Execute line 110 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\OpSelectFeaturesSpatial.cpp
> - MgServiceOperation.EndExecution line 533 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\base\ServiceOperation.cpp
> - MgServerDataReader.Serialize line 792 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataReader.cpp
> - MgServerDataProcessor.GetColumnDefinitions line 120 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDataProcessor.cpp
> - MgServerDataReader.GetPropertyCount line 103 file
> Thanks..
> Yash
> http://osgeo-org.1803224.n2.nabble.com/FDO-Toolbox-Connection-tp6410463p6413962.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110528/7bd8987a/attachment.html
