[mapguide-users] Re: Query Features does not work
Zac Spitzer zac.spitzer at gmail.com
Tue May 31 22:20:35 EDT 2011
for the 500 error in firebug, enable you need to enable php errors,
look for display_errors=off and change it to on php.ini which will should
show
what error is being thrown
On Wed, Jun 1, 2011 at 7:29 AM, Steve G <steve.golden at morganhill.ca.gov>wrote:
> Demanding solutions for your problems doesn't get you too far with this
> group...have you tried anything else on your own?  Like I've tried changing
> "A" and no results, changing "B" and no results, and changing "C" and still
> no results.
> Now that being said, have you changed anything in your filter between your
> querying of the shapefile and querying of the same data after importing to
> Postgres ?  You might want to check the differences between your column
> names between the two.  I noticed that uppercase column headings in
> shapefiles convert to lower case in Postgres.  Querying and filters can be
> case sensitive.
> -Steve
> http://osgeo-org.1803224.n2.nabble.com/Query-Features-does-not-work-tp6392727p6424637.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110601/15eef183/attachment.html
