[mapguide-users] Re: Anyone tried copying DWF files from library to session repository?
GIS4U johnniegis at gmail.com
Mon Nov 7 14:28:07 EST 2011
Yes, I have.  Essentially, if you rename the dwf to a zip extension and
look at the Unique ID in there you'll notice that each one is different.
In order for it to work that Unique ID needs to be updated in MapGuide so
that it refers to the new id not the old even though you have replaced the
file.
Regards,
Jonathon
On Mon, Nov 7, 2011 at 11:14 AM, tmblackflag <steve.calpoly at gmail.com>wrote:
> I've tried copying the file using the .NET System.IO class and no luck
> there
> either. The DWF is definitely making its way into the session repository
> folder, tried both the root folder and the DataFiles folders in there as
> well as updating the DrawingSource XML file's "SourceName" tag to point to
> the custom DWF to no avail.
> Has anyone tried to do this?
> System.IO.File.Copy("C:/Program Files/Autodesk/Autodesk Infrastructure Map
> Server 2012/Repositories/Library/DataFiles/" + myDwfName,
> Infrastructure Map Server 2012/Repositories/Session/" + myDwfName,true);
> http://osgeo-org.1803224.n2.nabble.com/Anyone-tried-copying-DWF-files-from-library-to-session-repository-tp6971598p6971704.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111107/13300009/attachment.html
