[mapguide-users] Re: Anyone tried copying DWF files from library to
session repository?
tmblackflag
steve.calpoly at gmail.com
Mon Nov 7 14:31:37 EST 2011
Can you elaborate on renaming the DWF to a ZIP file? As an example, i created
a simple map with only the DWF layer. When i access that map and look in the
session repository folder all I see are a .DBXML file, and a .DB file.
Even though I am certain this map is using DWF data, the Session/DataFiles/
folder is null.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Anyone-tried-copying-DWF-files-from-library-to-session-repository-tp6971598p6971768.html
