SV: [mapguide-users] Re: Need help finding classes/methods when
upgrading to MaestroAPI v4.0.0.6212
Hans Milling
hm at geograf.dk
Fri Nov 11 05:54:57 EST 2011
Thank you very much. That helped a lot. Now I just need to reqrite that part
of the code that used the HttpWebConnection.
Additional question.
RuntimeMapLayer:
The ResourceID is now the ObjectId?
The collection "IDs" has this been replaced by the IdentityProperties? Also
the Key property of the IDs is that now the Name property then?
The method Query where do I find that, or are there new ways to do this
also?
Yours sincerely Hans Milling...
-----Oprindelig meddelelse-----
Fra: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] På vegne af Jackie Ng
Sendt: 11. november 2011 11:40
Til: mapguide-users at lists.osgeo.org
Emne: [mapguide-users] Re: Need help finding classes/methods when upgrading
A major change in API design introduced with v3.0 is that you never create
HttpServerConnection and LocalNativeConnection objects (or any
implementation of IServerConnection) directly. Such implementations reside
in seperate assemblies which you never reference directly.
Look at the ConnectionProviderRegistry class in the API documentation. The
API documentation is part of the Maestro SDK package.
http://trac.osgeo.org/mapguide/wiki/maestro/SDK
I've blogged about the high level API design of the Maestro API:
http://themapguyde.blogspot.com/2011/05/introducing-re-vamped-maestro-api-pa
rt.html
http://themapguyde.blogspot.com/2011/06/introducing-re-vamped-maestro-api-pa
rt.html
I've also blogged about the topic of working with resources in the Maestro
API:
http://themapguyde.blogspot.com/2011/08/maestro-api-3-ways-to-create-and-wor
k.html
- Jackie
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/Need-help-finding-classes-methods-whe
n-upgrading-to-MaestroAPI-v4-0-0-6212-tp6984864p6984974.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
