[mapguide-users] Join between an Oracle spatial table and a view
Jonio, Dennis (Aviation)
DJonio at miami-airport.com
Wed Nov 23 09:00:06 EST 2011
Iulia,
I would recommend:
1) Create a “normal” Oracle view w/your join
2) Add the entry for it in user_sdo_geom_metadata. (No need for an index.)
3) Create a layer for the view …
Does all appear normal and as expected?
All that I am suggesting here is to gradually add complexity. No need to boil the ocean from the get-go. You can delete/remove this stuff later. But maybe you have already done these things.. in which case I am no help.
r,
dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111123/9714ff72/attachment.html
