[mapguide-users] Re: Passing the SessionId to a new map does not reflect the changes made
Jackie Ng jumpinjackie at gmail.com
Tue Nov 29 11:22:41 EST 2011
This is because your second viewer using the same session id has overwritten
the runtime map state from your first map in the process of initializing.
Using the same session id means the same resource id will be calculated for
saving the runtime map state and selection.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Passing-the-SessionId-to-a-new-map-does-not-reflect-the-changes-made-tp7043424p7043431.html
