[mapguide-users] Coordinate system override for SQL Server 2008
Zac Spitzer
zac.spitzer at gmail.com
Fri Oct 7 21:46:15 EDT 2011
did you try doing a CS override for the feature source?
On Sat, Oct 8, 2011 at 5:52 AM, Ward Kilby <wkilby at telus.net> wrote:
> Can MGOS transform coordinates from vectors stored in SQL S 2008? I am
> using
> Maestro 3.5, MGOS 2.2.
> Files stored in SQL in CS UTM11 and displayed on a map with CS UTM11 work
> well. But when they are displayed on a map with 'popular visualization CRS'
> they plot half a world away. The same data loaded into MGOS repository in
> most any projection reprojects into any desired map projection.
> Does data stored in SQL Server need to be in the same CS as it will be
> displayed? Or have I missed something.
> Thanks
> http://osgeo-org.1803224.n2.nabble.com/Coordinate-system-override-for-SQL-Server-2008-tp6870641p6870641.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111008/85e903a2/attachment.html
