[mapguide-users] Re: Generate a pdf view of the current map
Pedro Venâncio pedrongvenancio at yahoo.com
Mon Oct 10 06:09:30 EDT 2011
Hello everyone,
Excellent sharing Ram282!
I made all these changes, but when I use the Fusion Print on an application created in Maestro, the print works as before, with normal printablepage.
I am using the original print widget, it is necessary to make any changes to the widget in Maestro?
I have MapGuide 2.2 with PHP on Windows7 x64.
Thank you very much!
Best regards,
Pedro
----- Original Message -----
I didn't need luck, just your help!!!  Your changes worked.  Just to note:
mappdf.php
118     $tempMapImgPath .= $ImageType.$sessionId.time().$ImageFormat;   //
(dot before equal) on saveImage function
Should be at line 128
Also, you need to have a "fonts" folder in the same directory as fpdf.php
file (typical is C:\Program
Files\OSGeo\MapGuide\Web\www\fusion\layers\MapGuide\php)
The resulting pdf image isn't the best quality, so I'll have to figure out
some additional tweaks...(anyone care to share?), but pdf creation at least
is possible.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Generate-a-pdf-view-of-the-current-map-tp5264270p5843624.html
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
