[mapguide-users] Re: MaestroAPI - Runtime Map From Session Exception
Jackie Ng jumpinjackie at gmail.com
Fri Oct 14 00:53:59 EDT 2011
The map name is simply a convenience shortcut used by the official API so
load/save runtime map states to a resource id of the following form:
Session:SESSIONID//MAPNAME.Map
With the examples, we're opening a runtime map state of the map that was
created when the Web Layout used by the sample was loaded. The Maestro API
is more explicit about where you're loading/saving runtime map state from,
so you need to specify the full resource id then opening instead of just the
map name.
I should probably add a convenience API so that you can just specify the map
name, just like you would in the official API.
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MaestroAPI-Runtime-Map-From-Session-Exception-tp6889144p6891307.html
