[mapguide-users] Re: Tooltip - Display info from all (above) map
layers
ddriver
drunkdriv3r at gmail.com
Fri Oct 14 14:05:56 EDT 2011
Hi, the data comes from shp and dbf files. Would this work?
On Fri, Oct 14, 2011 at 8:43 PM, Steve G [via OSGeo.org] <
ml-node+s1803224n6893408h35 at n2.nabble.com> wrote:
> How is your data stored? If you are using a database on the backend, then
> you could just create a view and bring in the necessary data from each layer
> into the view and then create a single layer and tooltip from the view.
> -Steve
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/Tooltip-Display-info-from-all-above-map-layers-tp6891565p6893408.html
> To unsubscribe from Tooltip - Display info from all (above) map layers, click
> here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6891565&code=ZHJ1bmtkcml2M3JAZ21haWwuY29tfDY4OTE1NjV8LTYwMjYyNzQ3NQ==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tooltip-Display-info-from-all-above-map-layers-tp6891565p6893490.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111014/3411cc10/attachment.html
