[mapguide-users] Re: Tooltip - Display info from all (above) map
layers
Steve G
steve.golden at morganhill.ca.gov
Fri Oct 14 13:43:18 EDT 2011
How is your data stored? If you are using a database on the backend, then
you could just create a view and bring in the necessary data from each layer
into the view and then create a single layer and tooltip from the view.
-Steve
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Tooltip-Display-info-from-all-above-map-layers-tp6891565p6893408.html
