[mapguide-users] FDO 3.4 compile error
Dorin
did_1414 at yahoo.com
Tue Oct 25 06:44:24 EDT 2011
on the page http://mapguide.osgeo.org/download/releases/2.1.0
i writen for this release is needed
Requires FDO 3.4.0 which is available from fdo.osgeo.org.
that I tried to in stall on debian 2.6 FDO 3.4.0
Thanks
Release 2.1.0
Submitted by trevorwekel on Thu, 2009-11-19 20:16.
Release Notes - Up-to-date notes about this release.
Source Code
MapGuide source code for this release is available from the Subversion source control system. Is can be browsed online using the Browse Source button in Trac. With the Subversion command line client installed, the source can be retrieved using
svn checkout https://svn.osgeo.org/mapguide/branches/2.1/MgDev MgDev
MapGuide 2.1 requires FDO 3.4.0 which is available from fdo.osgeo.org.
mapguideopensource-2.1.0.4283-src.tar.gz [246,780,039 bytes]
md5: 33be6be518a0279af71277c57aed3e24
For those without Subversion, a compressed tar file that contains source code for both the MapGuide Server and MapGuide Web Server Extensions with configure / make / make install scripts.
Source for the Apache Web Server, PHP and Tomcat with a shell script to automatically build and configure these tools for MapGuide Open Source is also included under Oem/LinuxApt.
Windows Installers
MapGuideOpenSource-2.1.0.4283-Final.exe [120,369,204 bytes]
md5: f5b86032f72f242329450b16634abba7
Self extracting executable that will install the MapGuide Server and MapGuide Web Extensions on Microsoft Windows.
Other Binaries
None yet
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Tuesday, October 25, 2011 9:59 AM
Subject: Re: [mapguide-users] FDO 3.4 compile error
can you describe you environment? platform, arch, version?
any reason you are using such an old version of FDO?
On Tue, Oct 25, 2011 at 5:40 PM, Dorin <did_1414 at yahoo.com> wrote:
> I had the following error on the compiling FDO 3.4.0:
> libtool: link: g++ testepsg.o -o .libs/testepsg
> /usr/src/fdo-3.4.0/Thirdparty/gdal/.libs/libgdal.so -L/usr/lib
> /usr/lib/libexpat.so -lxerces-c -lpthread -lrt -ldl /usr/lib/libcurl.so
> libtool: link: creating testepsg
> make[1]: Leaving directory `/usr/src/fdo-3.4.0/Thirdparty/gdal/apps'
> make[1]: Entering directory `/usr/src/fdo-3.4.0/Thirdparty'
> make[1]: *** No rule to make target
> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', needed by `all-am'. Stop.
> make[1]: Leaving directory `/usr/src/fdo-3.4.0/Thirdparty'
> make: *** [install-recursive] Error 1
> Please help me someone to solve this.
> Dorin
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111025/1400e332/attachment.html
