[mapguide-users] FDO 3.4 compile error
Trevor Wekel
trevor_wekel at otxsystems.com
Tue Oct 25 11:18:52 EDT 2011
Debian 2.6? That does not seem to be listed in Distrowatch. Are you using a variant of Debian?
http://distrowatch.com/table.php?distribution=debian
From what I recall, FDO compiles older versions of xerces and xalan (as does MapGuide). Depending on the Linux distro, the gcc compiler may not successfully compile the older sources. I think gcc 4.1 works.
Regards,
Trevor
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dorin
Sent: October 25, 2011 4:44 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] FDO 3.4 compile error
on the page http://mapguide.osgeo.org/download/releases/2.1.0
i writen for this release is needed
Requires FDO 3.4.0 which is available from fdo.osgeo.org<http://fdo.osgeo.org/>.
that I tried to in stall on debian 2.6 FDO 3.4.0
Thanks
Release 2.1.0
Submitted by trevorwekel on Thu, 2009-11-19 20:16.
Release Notes<http://trac.osgeo.org/mapguide/wiki/Release/2.1/Notes> - Up-to-date notes about this release.
Source Code
MapGuide source code for this release is available from the Subversion source control system. Is can be browsed online using the Browse Source<http://trac.osgeo.org/mapguide/browser/branches/2.1> button in Trac. With the Subversion command line client installed, the source can be retrieved using
svn checkout https://svn.osgeo.org/mapguide/branches/2.1/MgDev MgDev
MapGuide 2.1 requires FDO 3.4.0 which is available from fdo.osgeo.org<http://fdo.osgeo.org/>.
mapguideopensource-2.1.0.4283-src.tar.gz<http://download.osgeo.org/mapguide/releases/2.1.0/mapguideopensource-2.1.0.4283-src.tar.gz> [246,780,039 bytes]
md5: 33be6be518a0279af71277c57aed3e24
For those without Subversion, a compressed tar file that contains source code for both the MapGuide Server and MapGuide Web Server Extensions with configure / make / make install scripts.
Source for the Apache Web Server, PHP and Tomcat with a shell script to automatically build and configure these tools for MapGuide Open Source is also included under Oem/LinuxApt.
Windows Installers
MapGuideOpenSource-2.1.0.4283-Final.exe<http://download.osgeo.org/mapguide/releases/2.1.0/MapGuideOpenSource-2.1.0.4283-Final.exe> [120,369,204 bytes]
md5: f5b86032f72f242329450b16634abba7
Self extracting executable that will install the MapGuide Server and MapGuide Web Extensions on Microsoft Windows.
Other Binaries
None yet
To: MapGuide Users Mail List <mapguide-users at lists.osgeo.org>
Sent: Tuesday, October 25, 2011 9:59 AM
can you describe you environment? platform, arch, version?
any reason you are using such an old version of FDO?
On Tue, Oct 25, 2011 at 5:40 PM, Dorin <did_1414 at yahoo.com<mailto:did_1414 at yahoo.com>> wrote:
> I had the following error on the compiling FDO 3.4.0:
> libtool: link: g++ testepsg.o -o .libs/testepsg
> /usr/src/fdo-3.4.0/Thirdparty/gdal/.libs/libgdal.so -L/usr/lib
> /usr/lib/libexpat.so -lxerces-c -lpthread -lrt -ldl /usr/lib/libcurl.so
> libtool: link: creating testepsg
> make[1]: Leaving directory `/usr/src/fdo-3.4.0/Thirdparty/gdal/apps'
> make[1]: Entering directory `/usr/src/fdo-3.4.0/Thirdparty'
> make[1]: *** No rule to make target
> `apache/xml-xalan/c/lib/libxalan-c.so.17.0', needed by `all-am'. Stop.
> make[1]: Leaving directory `/usr/src/fdo-3.4.0/Thirdparty'
> make: *** [install-recursive] Error 1
> Please help me someone to solve this.
> Dorin
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20111025/9765e8fb/attachment.html
