[mapguide-users] Error: Failed to stylize layer: An exception
occurred in FDO component. Connect failed
Zac Spitzer
zac.spitzer at gmail.com
Thu Oct 27 04:54:40 EDT 2011
I'd suggest contacting Autodesk given you are using the commercial edition
and it's a regression from earlier verions
On Thu, Oct 27, 2011 at 7:15 PM, Hans Milling <hm at geograf.dk> wrote:
> There is no problem opening the files in MapInfo, also they used to work with 2011 and 2009 version. There is no DBF file involved.
> This is the output of the OGRInfo tool on the TAB file:
> Had to open data source read-only.
> INFO: Open of `c:\WebData\┼rhus\KORT\ejendom.TAB'
> using driver `MapInfo File' successful.
> 1: ejendom
> Hans...
> -----Oprindelig meddelelse-----
> Fra: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] På vegne af Zac Spitzer
> Sendt: 27. oktober 2011 10:00
> Til: MapGuide Users Mail List
> Emne: Re: [mapguide-users] Error: Failed to stylize layer: An exception occurred in FDO component. Connect failed
> do you have dbf files there as well?
> can ogrinfo read and identify the files correctly?
> On Thu, Oct 27, 2011 at 6:56 PM, hm <hm at geograf.dk> wrote:
>> Hi All
>> I just installed Autodesk Infrastructure Studio 2012, but now some of my
>> layers are not working. The layers not working are all based on
>> TAB/MAP/ID/IND files. Layers from e.g. SQL Server works fine.
>> I have added the ORGProvider.dll (and all dependencies) to the bin\FDO
>> folder. Also ensured that it is FDO3.6 to match the existing version. The
>> providers.xml also have a reference to the dll.
>> When I try to preview a layer already created using the TAB/MAP/ID/IND files
>> I get the following error in the Logs\error.log:
>> <2011-10-27T09:00:21> 4060 Ajax Viewer ::1 Administrator
>> Error: Failed to stylize layer: Adresse
>> Connect failed:
>> StackTrace:
>> - MgMappingUtil.StylizeLayers() line 820 file
>> d:\build\mge2012\build_42.2\ent\os\server\src\services\mapping\MappingUtil.cpp
>> When I delete the layer and add it again using Maestro, add feature and
>> select OSGeo FDO provider for OGR, type the path to the TAB file in the
>> datasource and push the Test Connection button I get the following error:
>> <2011-10-27T09:22:52> 5108 MapGuide Maestro v3.5.0.6071 ::1 Administrator
>> Error: An exception occurred in FDO component.
>> Connect failed:
>> StackTrace:
>> - MgFeatureServiceHandler.ProcessOperation() line 83 file
>> d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\FeatureServiceHandler.cpp
>> - MgOpTestFeatureSourceConnection.Execute() line 100 file
>> d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>> - MgServerFeatureService.TestConnection() line 234 file
>> d:\build\mge2012\build_42.2\ent\os\server\src\services\feature\ServerFeatureService.cpp
>> - MgFdoConnectionManager.Open() line 313 file
>> d:\Build\MGE2012\BUILD_42.2\Ent\OS\Server\src\Common\Manager\FdoConnectionManager.cpp
>> - MgFdoConnectionManager.CacheFdoConnection() line 985 file
>> - MgFdoConnectionManager.Open() line 977 file
>> Does anyone have a clue what I have done wrong? If you need any more
>> information I will be happy to share it.
>> Best Regards Hans Milling
>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-Failed-to-stylize-layer-An-exception-occurred-in-FDO-component-Connect-failed-tp6935422p6935422.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer
+61 405 847 168
