[mapguide-users] Re: Properties item list
JanvW
jan.vonwartburg at bl.ch
Thu Sep 8 01:53:45 EDT 2011
Sorry for digging out this older post.
To show values from an attribute in the dropdown list instead of the count
of the values, one can do this:
Modify the function OnSelectedFeatureLayerChanged() in ajaxmappane.templ.
var sLayer = document.getElementById("selLayers");
var layerIdx = sLayer.selectedIndex;
var layerName = sLayer.options[layerIdx].value;
var count = selFeatures[layerName].length;
var auswahl = "";
var sFeature = document.getElementById("selFeature");
sFeature.length = 0;
for (var i = 1; i <= count; i++)
// depending on the selected layer a different attribute (key) value
is being read out of selFeatures
// and saved in auswahl
switch (layerName) {
case "Schutzzonenflaechen": auswahl =
selFeatures.Schutzzonenflaechen[i-1].values[2].value; break;
case "Schutzzonenpunkte": auswahl =
selFeatures.Schutzzonenpunkte[i-1].values[0].value; break;
default: auswahl = i;
if (auswahl=="" || auswahl=="-") auswahl = i; // when empty or "-", change
to count
var opt = new Option();
opt.text = auswahl; // fill in the result
opt.value = 1;
if (msie)
sFeature.add(opt);
else
sFeature.add(opt, null);
if (count > 0)
sFeature.selectedIndex = 0;
OnSelectedFeatureChanged();
Regards,
Jan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Properties-item-list-tp6669969p6770603.html
