[mapguide-users] Fusion layout is blank
Kevin Pelgrims Kevin.Pelgrims at realdolmen.com
Sun Sep 18 09:45:44 EDT 2011
Elliott,
Did you check for JavaScript errors? I recommend using Firefox and Firebug to see what's going wrong. That should give you some clues.
Kevin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of elliott17
Sent: zaterdag 17 september 2011 0:02
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Fusion layout is blank
I am trying to view a map with the fusion layout.  Everything works fine in the ajax viewer.
I am using MGOS 2.2, Server 2008, IIS 7 with Maestro 3.5.  I downloaded Fusion 2.2.
When I save the layout, the ApplicationDefinition.xml file is not updated.
When I view the url, no layers or widgets appear.
Thanks for any insight into my problem.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-layout-is-blank-tp6802416p6802416.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
