[mapguide-users] Re: Fusion layout is blank
Greg
gbneff at cid.utah.gov
Mon Sep 19 15:10:45 EDT 2011
I am fairly new to this so I hope that if I say anything incorrect someone
here will correct it:
As I understand it, when you modify a flexible layout and save it, the
modified application is saved to the library and the
ApplicationDefinition.xml in the folder of the template is not modified. So
that part is the way it should be.
I assume you are trying to view the url from Maestro which should work.
What coordinate system and units are you using?
I tried to use a projection with units in feet and Fusion did not like it.
I created a new map definition using a different projection with meters,
assigned it to my flexible layout and everything worked.
I think there is a bug in fusion layouts where the map definition is in
feet. Maybe this is the problem you are experiencing.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Fusion-layout-is-blank-tp6802416p6809729.html
