[mapguide-users] changes in ajaxmappane.templ
anand anand.speck at gmail.com
Thu Sep 22 00:48:19 EDT 2011
hi all,
I'm using MGOS 2.0 with IIS 5.1. I need to draw a line on map so, I wrote a
line of code under Onmousedown() event inside if(digitizing). But it gives
only a single point where as i need two points (that is the line
coordinates) The following is the code i've written to get the coordiantes
into my application:
if(digitizing)
        digitizer.MouseDown(e, x, y);
	//parent.GetTaskFrame().GetTaskPane().DigitizeLine();
	parent.GetTaskFrame().GetTaskPane().eLine();
	return false;
Can any one tell me how to get the line coordinates into my application
after drawing a line..
And is there any mistake i'm doing in getting the coordinates??
View this message in context: http://osgeo-org.1803224.n2.nabble.com/changes-in-ajaxmappane-templ-tp6818898p6818898.html
