[mapguide-users] Re: Search for a feature based on feature ID
ddriver drunkdriv3r at gmail.com
Wed Sep 28 07:31:04 EDT 2011
Ok, I just tried it, but it didn't help...I also tested it with 3 seconds
(3000)... still no zooming in.
If I remove the first two lines where I set the selection, and use the
ZoomToView() function with a set of coordinates and zoom level, zooming
works. But if I add it after the SetSelectionXML(), nothing. So it seems
it's only executing the first command... Any other suggestions or a way in
which I could find out why it's acting like this?
Thanks,
DD
On Wed, Sep 28, 2011 at 1:20 PM, GordonL [via OSGeo.org] <
ml-node+s1803224n6839790h77 at n2.nabble.com> wrote:
> Sometimes you have a timing issue.
> You could try waiting for a second..
> setTimeout(function(){parent.parent.ExecuteMapAction(10);},1000);
> gordon
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1803224.n2.nabble.com/Search-for-a-feature-based-on-feature-ID-tp6829659p6839790.html
>  To unsubscribe from Search for a feature based on feature ID, click here<http://osgeo-org.1803224.n2.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=6829659&code=ZHJ1bmtkcml2M3JAZ21haWwuY29tfDY4Mjk2NTl8LTYwMjYyNzQ3NQ==>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Search-for-a-feature-based-on-feature-ID-tp6829659p6839822.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20110928/755df161/attachment.html
