[mapguide-users] Re: Search for a feature based on feature ID
GordonL
gordon.luckett at arrowgeomatics.com
Wed Sep 28 09:34:58 EDT 2011
Does the SetSelectionXML actually select a feature?
Put top.top.ExecuteMapAction(10); into InvokeScript to test the code
- if it doesn't work, then there might be an install issue.
Try an alert to make sure the XML is correct:
alert(whatevertheselectionXMLis);
gordon
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Search-for-a-feature-based-on-feature-ID-tp6829659p6840210.html
