[mapguide-users] Re: Refresh Default Layer States w/o Refresh Map
Hans Milling hm at geograf.dk
Mon Apr 2 01:35:20 EDT 2012
Are you using the MaestroAPI?
If so, do this:
When the application initializes (or page_load) do this:
Dictionary<string, bool>initial_states = new Dictionary<string, bool>();
foreach (RuntimeMapLayer l in map.Layers)
  initial_states.add(l.ObjectId, l.Visible);
Now when the user presses your "reset layer visibility" button do this:
  l.Visible = initial_states[l.ObjectId];
Then in javascript you need to go redraw all the layers I think, looping
trough the layers in your OpenLayers map and call the
.layers[i].redraw(true); method.
Best regards Hans Milling...
View this message in context: http://osgeo-org.1560.n6.nabble.com/Refresh-Default-Layer-States-w-o-Refresh-Map-tp4675693p4677927.html
