[mapguide-users] OnMapOverlayImageLoadedError and JS-error
David Das Neves
neves at systemtechnik.net
Mon Apr 2 09:28:43 EDT 2012
Good day together,
I have a problem in the ajaxmappane.templ which I do not understand.
It has somehow to do something with the computer /settings on it because this is the first of 7 PCs where this error occurs on an absolutely equal data structure.
Sometimes the function "OnMapOverlayImageLoadedError(e)" is run and then an js error occurs because:
function OnMapOverlayImageLoadedError(e)
var frmParent = parent.frames["tbFrame"];
var objDivRefresh = frmParent.document.getElementById("divRefresh");
if(objDivRefresh != null)
objDivRefresh.style.display='none';
mapLoading = false;
var text = this.req.responseText;
var message = text;
var startPos = text.indexOf("<h2>");
if(startPos != -1)
startPos = startPos + 4;
var endPos = text.indexOf("</h2>", startPos);
if(endPos != -1)
message = text.substring(startPos, endPos);
alert(message);
return false;
"req" is null.
So I have some questions -
- When can the "OnMapOverlayImageLoadedError" be thrown?
- How can it be that req is null?
- Will there be any other possible issues if I just ignore the whole function?
Thanks for any help.
Greetings
David
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120402/e27996eb/attachment.html
