[mapguide-users] Re: MapGuide 2.4 Beta?
Jackie Ng jumpinjackie at gmail.com
Wed Apr 18 09:44:34 EDT 2012
In such cases, you should extract the internal MSI using 7-zip and run that
msi like so:
msiexec /l*v install.log /i path/to/the.msi
Windows installer will then log everything to install.log
But I'm pretty sure I know what's wrong. You should check and remove
anything in IIS (via IIS manager) that could conflict with what the
installer will be creating. A rough checklist would be:
 - FastCGI applications
 - Virtual Directories (eg. mapguide)
 - Application Pools (eg. MapGuide24AppPool)
I've put up some preliminary release notes as well:
http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-Beta-tp4553155p4894252.html
