[mapguide-users] Re: MapGuide 2.4 Beta?
Ivan Miličević Ivan.Milicevic at supranet.hr
Thu Apr 19 02:34:17 EDT 2012
Hello Jackie,
where can we (community) see the list of changes for 2.4beta?
Thank you.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
Sent: Wednesday, April 18, 2012 3:45 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: MapGuide 2.4 Beta?
In such cases, you should extract the internal MSI using 7-zip and run that msi like so:
msiexec /l*v install.log /i path/to/the.msi
Windows installer will then log everything to install.log
But I'm pretty sure I know what's wrong. You should check and remove anything in IIS (via IIS manager) that could conflict with what the installer will be creating. A rough checklist would be:
 - FastCGI applications
 - Virtual Directories (eg. mapguide)
 - Application Pools (eg. MapGuide24AppPool)
I've put up some preliminary release notes as well:
http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes
- Jackie
View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-Beta-tp4553155p4894252.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
