[mapguide-users] Re: MapGuide 2.4 Beta?
Zac Spitzer
zac.spitzer at gmail.com
Thu Apr 19 02:50:21 EDT 2012
release notes are on the wiki
http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes
z
2012/4/19 Ivan Miličević <Ivan.Milicevic at supranet.hr>:
> Hello Jackie,
> where can we (community) see the list of changes for 2.4beta?
> Thank you.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Wednesday, April 18, 2012 3:45 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Re: MapGuide 2.4 Beta?
> In such cases, you should extract the internal MSI using 7-zip and run that msi like so:
> msiexec /l*v install.log /i path/to/the.msi
> Windows installer will then log everything to install.log
> But I'm pretty sure I know what's wrong. You should check and remove anything in IIS (via IIS manager) that could conflict with what the installer will be creating. A rough checklist would be:
> - FastCGI applications
> - Virtual Directories (eg. mapguide)
> - Application Pools (eg. MapGuide24AppPool)
> I've put up some preliminary release notes as well:
> - Jackie
> View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-Beta-tp4553155p4894252.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
