[mapguide-users] Re: MapGuide 2.4 Beta?
Andrew DeMerchant
andrew.demerchant at gemtec.ca
Thu Apr 19 07:57:40 EDT 2012
Does the gdal work ok on x64 in this version? Any limitations or special
instructions?
Andrew
On 12/04/19 3:50 AM, Zac Spitzer wrote:
> release notes are on the wiki
> http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes
> z
> 2012/4/19 Ivan Miličević<Ivan.Milicevic at supranet.hr>:
>> Hello Jackie,
>> where can we (community) see the list of changes for 2.4beta?
>> Thank you.
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
>> Sent: Wednesday, April 18, 2012 3:45 PM
>> To: mapguide-users at lists.osgeo.org
>> Subject: [mapguide-users] Re: MapGuide 2.4 Beta?
>> In such cases, you should extract the internal MSI using 7-zip and run that msi like so:
>> msiexec /l*v install.log /i path/to/the.msi
>> Windows installer will then log everything to install.log
>> But I'm pretty sure I know what's wrong. You should check and remove anything in IIS (via IIS manager) that could conflict with what the installer will be creating. A rough checklist would be:
>> - FastCGI applications
>> - Virtual Directories (eg. mapguide)
>> - Application Pools (eg. MapGuide24AppPool)
>> I've put up some preliminary release notes as well:
>> - Jackie
>> View this message in context: http://osgeo-org.1560.n6.nabble.com/MapGuide-2-4-Beta-tp4553155p4894252.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
GEMTEC Limited <http://www.gemtec.ca/>
*Andrew DeMerchant*
tel: 506.453.1025 / toll-free: 1.877.243.6832
fax: 506.453.9470
Skipped content of type multipart/related
