[mapguide-users] Re: Oracle layer based on a view: I can't select
Franz1965
fsozzi at INTERCAD.CH
Sat Apr 21 03:18:40 EDT 2012
zspitzer wrote
> you just need to indicate in the view which column is to be treated as
> the pk, I think the directive is primary_key(g.fid) but you will need
> to google this
Hi Zac,
Thanks for suggestion.
Yes I've manually rebuilt primary key (the view had one) and now it works
View this message in context: http://osgeo-org.1560.n6.nabble.com/Oracle-layer-based-on-a-view-I-can-t-select-tp4903887p4904464.html
