[mapguide-users] Re: Oracle layer based on a view: I can't select
Zac Spitzer
zac.spitzer at gmail.com
Sat Apr 21 03:41:27 EDT 2012
cool, hey can you post the syntax for other to see?
On Sat, Apr 21, 2012 at 5:18 PM, Franz1965 <fsozzi at intercad.ch> wrote:
> zspitzer wrote
>> you just need to indicate in the view which column is to be treated as
>> the pk, I think the directive is primary_key(g.fid) but you will need
>> to google this
> Hi Zac,
> Thanks for suggestion.
> Yes I've manually rebuilt primary key (the view had one) and now it works
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Oracle-layer-based-on-a-view-I-can-t-select-tp4903887p4904464.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
