[mapguide-users] Question RE using a Google map base layer.
Zac Spitzer
zac.spitzer at gmail.com
Wed Aug 1 07:12:58 PDT 2012
this is the code which needs tweaking
http://trac.osgeo.org/fusion/browser/trunk/widgets/CursorPosition.js
On Wed, Aug 1, 2012 at 7:19 PM, JamesDudden
<jamesdudden at blueyonder.co.uk> wrote:
> Hi,
> I am using a Fusion web layout and Google as my External Provider/base map
> set up using the WGS84.PseudoMercator coordinate system and all works fine.
> The problem is that the coordinate system that now displays in the
> bottom-left corner of the map window is meaningless to the users.
> So, can I display a different coordinate system in the status bar to what
> the actual map is based on - what I would like is the British National Grid
> XY?
> Following on from this, when changing to a map using the
> WGS84.PseudoMercator coordinate system my preset zooms are all suddenly way
> off - does anyone know what's going on here and if there'e anyway to fix it?
> Any help or comments appreciated.
> Regards
> JD
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Question-RE-using-a-Google-map-base-layer-tp4992347.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
