[mapguide-users] Thematic maps on Non Spatial Data
Zac Spitzer
zac.spitzer at gmail.com
Wed Aug 15 21:57:08 PDT 2012
doing it in the database is the recommended approach, it scales
and performs far better than any other approach
plus you have the opportunity to tune a database view using indexes etc
On Thu, Aug 16, 2012 at 2:54 PM, Jamo <adam.jamison at portbris.com.au> wrote:
> So we have two tables one with say geometry and an id and one with an id and
> attributes...?
> I have a similar setup here but I'm affraid the only way to accomplish the
> task is to join them either at the DB end or at mapguide.
> I join them at the DB so whenever a change is made it triggers to modify the
> combined table so then you maintain the spatial data and the external data
> is simply appended when it changes.
> I have used this to join our cadastre (Spatial Data) to our Land Management
> System (Attribute Data).
> Hope that helps
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Thematic-maps-on-Non-Spatial-Data-tp4994300p4995525.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
http://www.ennoble.com.au
http://zacster.blogspot.com
+61 405 847 168
