[mapguide-users] Thematic maps on Non Spatial Data
nanda kishor
nandakishorks2010 at gmail.com
Thu Aug 16 21:20:05 PDT 2012
@Zac Spitzer,
Is it possible, that a customized widget can be developed; In that a
non-spatial table can be joined with the spatial layer(@ client_end) from
the final table, a thematic map can be generated and later it get displayed.
Thanks in Advance,
--Nanda Kishor
On Thu, Aug 16, 2012 at 10:27 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> doing it in the database is the recommended approach, it scales
> and performs far better than any other approach
> plus you have the opportunity to tune a database view using indexes etc
> On Thu, Aug 16, 2012 at 2:54 PM, Jamo <adam.jamison at portbris.com.au>
> wrote:
> > So we have two tables one with say geometry and an id and one with an id
> and
> > attributes...?
> > I have a similar setup here but I'm affraid the only way to accomplish
> the
> > task is to join them either at the DB end or at mapguide.
> > I join them at the DB so whenever a change is made it triggers to modify
> the
> > combined table so then you maintain the spatial data and the external
> data
> > is simply appended when it changes.
> > I have used this to join our cadastre (Spatial Data) to our Land
> Management
> > System (Attribute Data).
> > Hope that helps
> > View this message in context:
> http://osgeo-org.1560.n6.nabble.com/Thematic-maps-on-Non-Spatial-Data-tp4994300p4995525.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer
> Solution Architect / Director
> Ennoble Consultancy Australia
> http://www.ennoble.com.au
> http://zacster.blogspot.com
> +61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120817/88b4a9e1/attachment.html>
