[mapguide-users] Do we need somewhere to maintain user widgets?
Zac Spitzer zac.spitzer at gmail.com
Wed Aug 22 20:11:35 PDT 2012
have you seen the fusion trac?
http://trac.osgeo.org/fusion/wiki/Widgets
all you need to do is create a ticket and attach a patch
On Thu, Aug 23, 2012 at 10:37 AM, Jamo <adam.jamison at portbris.com.au> wrote:
> I've been playing with the fusion viewer for a bit now and with recent
> enhancements I've moved my user based viewer over to the fusion layout :)
> I'm keen to share what few widgets I've made / modified in the hope they can
> be of help or further improved by other.
> perhaps we need some kind of central store for user based widgets? like a
> repository for them with a breif description and latest available version?
> I have a programming issue of writting everything site specific so if things
> don't work the way I planned its usually cause I've hard coded some local
> directory or something (just a disclaimer if something goes bang).
> Extended search widget, allows searchign on multiple layers and multiple
> properties.
> *- pobSearch*
> The main differences are.
> Filter can contain any amoun
> http://osgeo-org.1560.n6.nabble.com/file/n4997213/pobSearch.zip
> pobSearch.zip t of $USER_VARIABLE by adding a count to the end ,
> $USER_VARIABLE1, $USER_VARIABLE2, $USER_VARIABLE3, $USER_VARIABLE4 etc...
> Then in the UserVariables place a comma seperated list for the labels to be
> placed in the search dialog next to each variable.
> desc1,desc2,desc3,desc4 etc....
> Layers can contain any number of layer namesthe only restriction is they
> must all have the same properties to search on and the same properties to
> return for results.
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Do-we-need-somewhere-to-maintain-user-widgets-tp4997213.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
