[mapguide-users] Problem of selection with SQLite data in MapGuide
Zac Spitzer zac.spitzer at gmail.com
Sat Aug 25 06:46:51 PDT 2012
Can you try this file with 2.4 RC1
http://trac.osgeo.org/mapguide/wiki/Release/2.4/Notes ?
z
On Sat, Aug 25, 2012 at 12:51 AM, Tiphaine SCHMITT
<tschmitt at geomapgis.com>wrote:
>  Dear all,****
> First of all, i’m a new member of this mailing list and I’m working for
> Geomap Services in Chambéry, France.****
> I am currently working with a SQLite Database connection in MGOS 2.2 and
> I’m facing a problem of selection with a specific table. ****
> The problem occurs with the selection action done in the Maestro 4.0
> viewer (same problem with others versions). When  I try to select some
> objects I see an anarchic selection in the map which does not correspond to
> my action (cf. screenshot below). ****
> The table has been imported in SQLite from an Oracle database with others
> similar tables. The problem only occurs with this table while the others
> are working fine. The parameters of the MG FeatureSource and the content of
> the geometry_columns table in SQLite are exactly the same between the
> tables.****
> The selection action works fine in Autocad Map which makes me think that
> the error does not come from my data. The error.log does not give any
> information about this situation and no error message occurs. ****
> Here below, the Data connection screenshot.****
> Does anyone has already encountered this problem?****
> Thanks in advance for your support.****
> Best regards,****
> Tiphaine Schmitt****
> *Ingénieur d’Application*
> Savoie Technolac                                     Direct : +33 (0) 4
> 79 25 38 66****
> 48 av du Lac du Bourget                      Mobile : +33 (0) 6 27 44 66
> 65****
> Le Square A 17 - BP 210                     General : +33 (0) 4 79 25 38
> 80  ****
> 73374 Le Bourget du Lac                            Fax : +33 (0) 4 79 25
> 38 70****
> http://gs-web.geomapgis.com****
> [image: Description : Description :
> http://www.geomap-services.com/web/styles/gs/imgs/gs_150x54.jpg]<http://www.geomapgis.com/web/geomap-services/>
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20120825/bed5334e/attachment.html>
