[mapguide-users] MGOS - DWG / DXF
David Das Neves neves at systemtechnik.net
Thu Aug 30 04:10:26 PDT 2012
Ok... thx for the whole information guys ;)
We will try now first an other way to get those files working. Just "converting" them to sdf/shp - hopefully this tool(s) work properly.
Greetings
David
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Trevor Wekel
Gesendet: Mittwoch, 29. August 2012 19:04
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] MGOS - DWG / DXF
If you are using the Teigha libraries from the Open Design Alliance "ODA" for internal use only, ie. not selling or distributing applications, an Associate Membership will give you access to the libraries.  Higher level memberships in ODA also grant redistribution rights.
http://www.opendesign.com/Associate  Cost is $250 USD for the first year and a $100 renewal in subsequent years.
http://www.opendesign.com/Sustaining Cost is $5000 1st yr/$3000 renewal and grants unlimited distribution rights.
It should also be noted that the Teigha libraries are supported on Windows and Linux.  I have used them on CentOS 5 and they do work.  With the version I used, some of the extended entity information from AutoCAD Map was difficult to get at through Teigha.
ODA has posted a design specification for DWG files.  It may give a better indication as to what is supported and what isn't.  Object data and link templates are mentioned in the document but I suspect "mileage will vary".
http://opendesign.com/files/guestdownloads/OpenDesign_Specification_for_.dwg_files.pdf
Regards,
Trevor
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Gabriele Monfardini
Sent: August 29, 2012 1:29 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] MGOS - DWG / DXF
On Wed, Aug 29, 2012 at 5:08 AM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> The DWG driver support in OGR is through Teigha/ODA, so most
> definitely just vanilla AutoCAD and none of the vertical stuff like OD
> tables and Link Templates.
> Good luck finding binaries with DWG driver support built-in.
Also because "Open DWG Alliance" software has Open in the name, which is a good marketing point, but is available to download only for ODA members, which pay the quote.
Gabriele
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
