[mapguide-users] Is it possible to specify the schema version when connection to a WMS feature source?
Zac Spitzer
zac.spitzer at gmail.com
Mon Dec 10 18:30:59 PST 2012
BTW: there was a lot of work done for WMS compatibility after 2.2 which is
available in 2.4
http://trac.osgeo.org/mapguide/wiki/MapGuideRfc95
On Mon, Dec 10, 2012 at 10:18 PM, von Wartburg, Jan BKSD <
Jan.vonWartburg at bl.ch> wrote:
> That's it!
> I was adding '?VERSION=1.1.1' to the URL of the feature source and now it
> works.
> Thank you very much, Jackie!
> Jan
> P.S. I would like to find out why the FDO WMS provider doesn't like the
> 1.3.0 schema of this server...but for now, this issue is solved by adding
> the version parameter.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:
> mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jackie Ng
> Sent: Monday, December 10, 2012 11:48 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Is it possible to specify the schema version
> Actually, if the WMS server operates like how MapGuide serves WMS, you
> could probably pass in a VERSION parameter in the URL to indicate the WMS
> version you want to work with.
> - Jackie
> http://osgeo-org.1560.n6.nabble.com/Is-it-possible-to-specify-the-schema-version-when-connection-to-a-WMS-feature-source-tp5021855p5021857.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
Zac Spitzer
Solution Architect / Director
Ennoble Consultancy Australia
+61 405 847 168
URL: <http://lists.osgeo.org/pipermail/mapguide-users/attachments/20121211/7fdc42a2/attachment.html>
